joez said:Yes, i can. As soon as the glow plugs stop cycling i put her in gear and drive away. Normally takes less than 30 seconds, a lot less.
I love your LS2 comment, lets compare something made over 20 years later with an IDI diesel.![]()
As for fuel economy, at 230K miles, with bias ply 36's and 3.73's i still see over 20mpg.
I cant type anymore, im stopping while im ahead. I dont know what to adress next without my head exploding, some of you really are clueless, no offense.
I could be wrong, but I've never seen a 6.2L take off 30 seconds after stepping in the door when it's 10° outside.
You pulled the fuel injected "run on any angle" and "no 350 makes what a 6.2L does" cards. I proved you wrong. I noticed you didn't even touch the TPI 350.
Yes, diesels get better fuel economy than a carbureted motor of the same size. Duh. Add multiport fuel injection, modern engine design, and a diesel doesn't look nearly so good. I bet with 36s and 3.73s and your 20mpg the only thing it passes is the gas station. The only claim to fame the 6.2L has is its fuel economy. It isn't a bad wheeling motor because of its low-end torque but when you compare it to an injected smallblock it doesn't look as good. I'd have me a 2wd 6.2L pickup for tooling around in... but that's about as big of a purpose I see for one. You simply can't get enough power out of it.
If its not 1300 - 1500 then thats false advertising... so what is it then?
