goathearder
Hey everyone, I am going through all these little things 1 by 1 and next on my list is the play in the steering wheel. Basically, I can turn the steering wheel OR the steering shaft about 30 degrees before I get any movement of the tires. It isn't a problem per-se because other than that it drives and turns fine but its totally freakin annoying.
I checked out the rag joint and it seems ok but I have no idea what else to check. Is this common? I have a 73 if that makes a difference. I have heard of people doing XJ shaft swaps to get rid of the rag joint but I know that doesn't work on a 73 and I don't think the rag joint is the issue anyway.
Anything specific I can check if I take the steering box out?
Thanks,
John
Thanks,
John
Thought Tustin sounded familiar
