30spl 10b 8 lug 5.13 gears True Trac posi **new price list (parted out)
Re: 30spl 10b 8 lug 5.13 gears True Trac posi **will consider parting out
i need 8 lug hubs/rotors and backing plates. how much shipped to 77345?
Shipping hint: FedEx Ground is WAY cheaper than UPS! If they have a location near you, just sign up for an account on their web site. Then you can print out waybills on your computer. /forums/images/graemlins/cool.gif
BTW, how much are ya asking for the True Trac alone?
Are you referring to the lockouts or the hub/rotor assy and backing plates?
Lockouts alone are $30. Other prices are as posted.
Thanks for the tip
$265 + shipping
$145 including the bearings (again, they are Timkens) and warn premium hubs ($125less lockouts) + plus approx. $25 shipping (I figured 30lbs x 2 packages weight for my shipping estimate, it may be cheaper once I get it all packaged up and weighed, but you can count on $25 or less)
these are the same size spindles/bearings as my '91 half ton 10 bolt right? do the rotors have plenty of surface left on them?
FedEx ground is always cheaper for me, just make sure you go to an actual fedex staffed location with a fedex employee. those 3rd party mail room places double and tripple the costs for their profit.
Yup... When I originally got them, I got them for my '89 Jimmy in stock configuration.
I just had the rotors turned in February and they still looked good then. When I tear it all apart, I'll be happy to include pics of everything.
/forums/images/graemlins/whistling.gif
what ya looking for , for the ring and pinion
Hossbaby50 has tentatively committed to buying it for $100. You wanna be #2 in case the deal falls through?
Here is a rundown of the parts availible individually:
(Prices do not include shipping)
Detroit Trac-Loc w/ Timken side bearings 30 Spline: 265
Yukon 5.13 gear set: 100
Trac-loc & gear set together w/ bearings: 350
8 lug rotors & backing plates: 80
" " " w/ Warn premium hubs: 145
Warn premium hubs: 30
4" raised steering arm: 40
4" dropped drag link: 70
axle shafts, spindles, knuckles and other un mentioned items: make am an offer...
The only comitment I have so far is for the gears for $100 (Shipped) everthing else is still available....
/forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
Re: 30spl 10b 8 lug 5.13 gears True Trac posi **new price list (parted ou
I need the short side shaft, u-joint and outer how much do you want for that or do you want me to buy all the shafts?
You can have 'em all for 45 + shipping...
Individually $30 per side + shipping (one side includes both the main axle, stub saft & u-jouint).
If you want the warn premium hub to I'll throw those in for another $20 if you buy all, another $25 if you buy one side axle assy, $30 alone. Note these stub shafts also include new (3 mos old) end seals.
One last bump before going on Ebay...
