$31.00 for this??????
You could also use Butyl rubber "snot-caulk" or the urethane windsheild rubber stuff in a caulking tube,or "Great Stuff" foam to seal up that joint instead of weatherstripping...I've used pipe insulation on things like that for a gasket too...if you look in hardware stores they sell "rope caulking" made of the same foam as pipe insulation thats 3/8" in diameter,that would work well too...
