32 Spline front output Yoke?
doubletrouble
Milliken, Colorado
I got a 32 spline front output shaft from ORD for my 205 t case to replace the 10 spline. I have the front driveshaft that has the U-joint not the flange style. I put a rear 32 spline yoke on the front, it fit fine but the u joint part of the yoke is bigger. I think it is because the rear output yoke is made for straps, not the bolts like the front driveshaft has. Anybody know if there is a 32 spline yoke that will fit the front driveshaft? or do I have to switch to a flange style?
sounds like you swaped on a 1350 yoke from the rear.
front shaft stock will be much smaller joint than the 1350.
not much traffic in here. search in the garage. 32 spline front on 205 and other key words.
So you want to know if you can get a 1350 32 spline u-bolt style yoke for the front?
Yes, we have those.[/quo
I need a yoke that has the holes in it to put bolts threw and into the double carden on the rear of my front shaft. I had the 10 spline front output with the yoke style drive shaft. I want to keep my same front driveshaft and I need the 32 spline yoke to bolt to my driveshaft. Make any sense?
I have the spicer part number for the 10 spline yoke I just replaced it the beginning of summer. 2-4-4021X The 32 spline rear yoke fits the front drive shaft u joint but the bolt holes are farther apart.
First things first, measure the caps of the u-joint on your front driveshaft. Then we'll know which yoke you need.
As for the yoke you put on there, are there threads in the four holes?
OK, I measured the u joint it is just a hair under 3.25 outside to outside of caps across and just a hair under a 1 1/16 outside to outside of the cap. So I think it is a 1310 series u joint right? the measruements I have say that a 1310 u joint is 3.2188 across and the caps are 1.0625. So the yoke I need is a 32 spline 1310 u joint that the bolts slide threw from the transfer case side and thread into the double carden on the drive shaft. The old style before they went to the flange style on the half tons.:confused::dunno:
What you need is actually a 32 spline 1310 series CV yoke, the key part there being "CV". The ujoint size is 1310 but you're finding the problem yourself, the CV housing doesn't use the same hole spacing as a regular yoke so you need one built just for the CV joint. This is a relatively common jeep CV size so the yokes aren't too hard to find. We can get one for you from a couple places, just let know.
That would be great if you can get one for me. Should I just call and ask for you? Or do you have a part number?
