Wanted 32 spline NP241 input shaft
AJs72K5
blub-blub-blub-blub
Central Tx
Upgrading to a 4L80 and need to change out the input shaft on my 241. Anybody have a 32 spline input they'd like to part with?
Thanks!
EDIT: Ordered one from ORD
I may have one from a SYE conversion I did for my 90' NP241 t case. Still looking?
I do still need one. But I need to tear down the case to see which bearing style I have. Apparently there's two different 32 spline inputs for the 241.
I'll update this when I know for sure.
Why'd you change the input shaft with the SYE? It wasnt touched on the JB Conversions kit I did on mine
oh, it may be the other end, main shaft....not the input shaft. Sorry. I have the left over shaft from my JB conversions SYE kit. I'm thinking output shaft, and you need input....my bad.
Aj. I have a 93 driver drop 32 spline case. Complete setup. 100 for the whole thing. Pm me if you can use that style.
I did the same swap. Needs to be a shaft from the 94 and below to work with a 4L80E. hope this helps.
