32 spline th400 slip yoke
basing110
san diego
i need a good 32 spline slip yoke for a th400 if a driveshaft is attached that is fine need to try and get one asap i dont wanna spend an arm and a leg for a new one im in san diego
Would this be for a TH400 tranny, or for a transfer case? What size u-joint do you need? I'll need outside diameter, overall length and u-joint size to match you one up.
Jimbo
I may have a bolt on truck yoke. Of course it would still slip if the bolt wasn't installed. I'll check tonight when i get home from work.
Looks like he needs the slip yoke for a 2wd TH400 in a '34 Ford Pickup. I'm pretty sure the bolt on yoke would not work.
I think he is looking for the end of the driveshaft... not the slip yoke parts for the transmission.
ive got the tranny already i just need a 32 spline slip yoke to slide on the tailshaft ..u joint size doesnt really matter to much. since i will be doing a custom driveshaft anyways
I do have a 32 spline yoke but it is a truck bolt on style and i don't have the U-bolts for it either. Guess i'm not much help, sorry.
