well ive got a 4L80E i was eventually going to have built and swapped into my 6.2 rig to replace my th400. i was thinking that it might actually be cheaper to get a 700r4 built with a 32spline output shaft (ive already got 32spline doubler, and dont want to swap in a 27spline 203). if i went the 700r4 route, i could sell the 4L80E and all the parts i got with it, and get a "bullet-proof" 700r4. i would have a deep first, and a great overdrive, and it would definitely be an easier swap than the 4L80E. the only problem is the 32spline output shaft. i thought advance adapters made one, but i couldnt find it on the site. what do you guys think about that idea? i know people think they are weak, but if i got a built one to handle 650hp, i'm pretty sure it would be ok, no? i would end up having the 4L80E built anyways so i dont see that route being any cheaper.
i need overdrive regardless; 2500rpm at 65mph sucks with the diesel, so its either 700r4 with 32spline output or 4L80E. thoughts?
