Mikey von
I have a 1989 6.2L 3/4 ton Suburban. It currently has stock tires, 31.5", and wheels. The PO put a 4" lift with tuff country springs in front and blocks in the rear. I have 4.10 open gears in the 14b sf and 10b front. I want lockers soon. I currently have the th400 tranny, but will be upgrade to some type of OD (NV4500) hopefully next summer.
I like at 3500ft elevation in the Cascade Mts. The truck is a sorta daily driver, but does not get driven daily. Right now it is not to good for more than 65mph (It goes faster but the 6.2 is spinning pretty fast). There are tons of forrest service roads around here and I plan on getting into more wheeling. We do get snow.
My real concern is towing. I do not tow often, but do tow up to 12000lbs of firewood every now and then. I never go far with firewood and most of the time I am on forrest service roads. We are planning on getting a light weight travel trailer, somewhere in the 5-7K lb range. The travel trailer is a few years off at least though (unless my folks spring for it).
I can afford both 33's and the 35's. Should I just get the 35's and be done with it? Will I see much difference in towing? There is also the 34's.
Will an 8" rim be better or worse than a 10" rim with 35x12.5 trxus MT's? Desert Rat has a pretty good price on a package deal with 10" rims.
thanks,
michael
thanks,
michael
