No DRAC in a '89. Speedo cable.I'm running 33's with the stock 3.73, and it works like a charm. I do stay out of OD unless I hit the interstate. I never tow 2000lbs or more in OD. I do have the heavy duty engine oil cooler, but not one for the tranny yet.
I would definitely recommend modifying your DRAC to adjust speedometer for the 33's. Mine was off by 12%, but is now only 0.5% off. Not sure about '89 but my '91 its tied to ABS, Cruise and who knows what else.
Are the 3 digit RPO codes still on the sticker in your glovebox. They can be decoded online. Gearing is all Gxx if I recall correctly.How do I tell what gears I have now? Are all 89 gmc jimmy the same from factory? I dont see anything on the rear diff that says or in the glovebox. I also have a tranny cooler rated to tow 10,000 lbs.(I dont tow near that just small fishing boat) and stock engine oil cooler so I guess I should be ok with the 33,s. I do however have to climb alot of hills.
