I'm going to be putting a 4inch lift on my truck and can't decide on what size wheel and tires to run. What do you guys think? I am still running stock axles/gears and motor is stock except for the headers on order.
you live in Ionia? I'm just down the road in clarksville.save yorself the money on the lift.You can fit 35's with no lift and maybe slight trimming.Good enough for street driving.Unless of course you'll be flexing it out on the rocks/trails.Then you'll need lift.
Typically,4"/33's,6"/35's.But you'll find alot of guys on here runny little lift w/ alot of meat.Requires alot of trimming,so decide your ultimate goals for your K5 and go from there.
So the regear is worth the money then? I pretty much just use the truck for the sand dunes, some two tracks, could I get away without regearing or would the 35's just be stealing all my power with the lower gear ratio?Your overdrive tranny won't be happy either. I regeared from 3.73 to 4.10 when I switched to 3/4 ton running gear and was back to stock with 33's, but with 35's it kept kicking out of overdrive.
I think I have 3.73 gears. I looked up the code in my glovebox, GT4, and it said 3.73, but my truck is a 91 and that code page was for later trucks.What gears do you have now? If you have 3.73 then you might be happy on 33's, but not 35's. If you have 3.08 or 3.42 then you should re-gear IMHO.
I'm even closer than you thought.I'm in Saranac,just barely across the highway. Here's my direct e-mail so we're not polluting this guys thread.I think I have 3.73 gears. I looked up the code in my glovebox, GT4, and it said 3.73, but my truck is a 91 and that code page was for later trucks.
I just looked up more on that code and it says
"GT4 : AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)"
What does the DUP with 5 x 1 mean?
