Spray carb cleaner around the base of the carb,it may have a leak at the base gasketor maybe the EGR is open slightly as suggested--do not overlook the power brake booster ,and vacuum modulator,vacuum advance , as potential vacuum leaks,also make sure the pvc valve is working good.....vacuum gauge helps a lot diagnosing these issues..
It could be just a spark plug failing or a plug wire..usually a spark or compression issue will show up worse under load though..
