350 engine NOT heating up to operating temp.
87K5Newbe
Registered Member
Saratoga, Wy.
Hello, I have a Ramjet 350 MEFI4 swapped into my K5 by a previous owner.
My engin temp never seems to go above 140-160degrees when ideling or driving around town, or 2 tracks trails when hunting.
(this i a problem because it idles high when cold and if there is a load on the motor with the throttle closed the motor will drive me along the trail and when the clutch is pushed in the motor will rev to like 1500 rpm or higher and takes 15 or more seconds to come to idle again.)
On the highway running 60 to 70mph (FYI 3speed with granny, high axel gears so 70mph is probably over 2500/3000rpm. dont have a tach yet.) she will get right up to 190 ish on the gauge but not go above.
This is what i have done so far.
Fan cluch turns with resistance when cold and you can defiatly hear the fan noise when reving the motor in park or hard acceleration. so i assume that is workin properly.
replaced sending unit located on left head. connected to stock temp gauge in cluster. (ram jet temp sending unit is located on intake maniflold near thermosat housing)
I had a small leak on the lower radiator near the hose so i swapped the radiator to a new nappa radiator for a 350 with the long single core instad of 3 seperate cores.
Changed the thermostat to 180 safety stat. on first start up it locked in the open postion. noticed it was running even cooler than before, which a week or two later i found it and replaced it with a regular napa 180 thermosat.
I have verified motor temp with IR gun near thermostat on intake manifold and engine temp sending unit is 140F when idleing for 20 minutes.
outside temp has been between 70F to 30F. on the colder days interstate speeds she just runs cooler.
STUPID QUESTION: What holds the thermosat down on the intake maniflod. it appears the thermosat hose housing ID is larger than the OD of the thermosat and the gasket is the only thing holding the thermostat down. Thermostat fits nicely into the intake manifold groove.
I have no coolant bypasses on this motor, like some suggest for overheating on the ramjet350. I have the opposite problem.
any help will be appreciated.
Tho I don't have anything useful to help, I'm curious as how you like the Ramjet? I have the intake setup, just waiting on time n some other things before I put it on. Seems nobody uses it...
Can you block off the front of the radiator with card board reducing the surface area and see if the temps come up? Also do you know for sure that there is no air pockets making the sensor think its colder than it really is?
I have to block off the entire grill November thru May to have any hope of my 350 in the C10 warming up. Having electric fans does allow it to heat up driving around town, but highway driving requires the grill to be blocked. I also use a block heater in the winter so it starts the morning at a higher temperature.
I have a 180° thermostat but keep thinking about trying a 190°.
Are the fans on constantly? And how cold are we talking? 20* ambient should be no challenge for the engine to get to operating temp, except coasting down long hills when you might see enough heat transfer through airflow to drive engine temps down somewhat.
People (myself included in the past) underestimate how effective fan(s) are even at highway speeds.
190* thermostat won't hurt things, however for AC operation in summer I expect the colder thermostat may help, if the cooling system can keep it at 180*. If it's going over 180* in summer (or AC isn't a concern), then the thermostat really isn't doing anything except helping warm up the engine initially. A higher temp thermostat really hurts nothing EXCEPT potentially AC.
