Welp, got my new wieghts in and used the strongest spring and I still have the clatter! My wires cap and rotorbutton are old (4months) but in good shape. Could these things cause a clatter if 1 or any were bad? I have a BIG truck with 40's under it but no big brake kit yet, the truck really wont let me powerbrake it to see where the noise (which side) is coming from. So the only way to hear it is to actually drive it around, and between the tires and the flowmasters I really cant depict in the cab where its comin from. I got an accel curve kit with the 3 spring wieghts. Correct me if I'm wrong but isnt the white spring the strongest? If all the thing I listed today are correct or wouldnt cause a problem than I have no choice but to lean towards loose rockers =(. It's not a lifter cause the only time it makes the noise is under a 1/4 pedal load. slow start no noise, gunnin it no noise, cruising at or accelerating at 1/4 or so throttle clackclackclack lol. I took off the driverside valve cover and all the rockers seem tight just a small amount of side to side motion. Guess ill do the ol loosen till clatter, 1/2 turn back job =). any tips on keeping the oil off my headers? I dont have an old valve cover.
