Used 350 chevy from my 1984 blazer. Was previously bored 60 over and had an RV cam and Holley intake. Replacing it with a 383 I had built. Has a small oil leak but doesn’t burn oil or coolant. Oil pressure was low (1-2psi hot and 30-35psi at 3000rpm) but haven’t had any issues with it in the 3 years I’ve been driving and rock crawling with it. Just needs a carburetor to run. Plug wires come with it but aren’t pictured. Compression was 150-160psi when I tested it last year. Located in Georgetown. $500 obo local pick up only.
