350 SMALL BLOCK ,POINTS THAT THE SPARK PLUG WIRES OF ON DISTRIBUTER
newbe73
SD
can you give me a diagram or tell where the spark plug wires go from the distributor to the spark plugs. for a 350 small block on my 73 chevy blazer or tell me the firing order.
i am waiting right now for a response because i am working on it right now. COME ON GUYS I REALY NEED YOUR HELP NOW SO DO NOT JUST PASS MY QUESTION TELL ME!
1 8 4 3 6 5 7 2 starting from the post above the dwell adj. window on the cap going clockwise.
ok i sort of get it but it keeps misfiring but i know i am doing someting wrong here. here is kinda a diagram of want a am doing tell me what i am doing wrong
this is the cylinders the way i # ordered them
8 7
6 5
4 3
2 1
then this it the way i put them on the distributor
__________6___5_____
_______3_________7_____
_______4_________2_____
__________8___ 1_____
tell me what i am doing wrong plz
That is all correct. Now just make sure you have the engine on the compression stroke and not the exhaust stroke. Sounds like you have the timing 180* off
You might want to remember this for the next time ( I found out the hard way ) try moving the wires on the cap one position counter clockwise Sometimes the dis gets set for the later years and if you try to do it like the book for a 73 it will not fire..I moved mine and it fired right up...mike
Mike, you took the words right outta my mouth. I'm glad to see you gots yours running after the steam clean.
Ya thanks for that help..And after that I pulled the dis.and put new intake and all that and would ya belive I did it again(as homer sounding as possible) duh and double duh..lol
