Kocher93
I have a 89 350 tbi and it keeps retarding itself. I thought it was skipping on the chain, but isn't. I'll set it one day and itll be retarded later by a good amount. Any idea on the cause? and no the dist isn't loose.
30 seconds without battery power is overkill for clearing codes.Yea, going through all the steps. I Disconnect and set, turn it off and reconnect. I've also left it off the battery overnight. When it starts up and warm its around 16 and over the course of a couple of days itll retard itself about 20 degrees to a -4. I've set this trucks timing probably close to 10 times in the past month.
Lol oh boy... Talk about your can of worms! Yes a knock sensor can retard the timing. Thats it's job. You shouldn't disconnect it tho. It senses detonation in the motor and can save your motor from destroying itself.
You know thinking about it there was some metal shavings on my old dist and it was hard as hell to get out. Think my cam is missin a tooth or two?
