77crewcab
Is it possible to run a 350 tbi on a 454 until I find a 454 TBI? Also anyone know if you can get the 454 tbi adapter plate from GM still?
with a few mods. ask brian at www.tbichips.com good info and service. and then you wouldnt need a 454 tbi.
also you dont need the stk gm adaptor. if you dont want. get a aftermarket. stock has coolent running threw it for faster warmup and emmisions stuff.
Where can I get an aftermarket adapter? I haven't been able to find one, maybe I am just searching for the wrong thing. What type of mods are needed to the throttle body?
The heated adapter is to prevent the throttle plates from icing up. 454s suck a lot of air and dont have the exhaust crossover in the intake manifold like SBC the keep the throttle plates warm. SO they run hot coolant thru the adapter to warm the TB base.
Icing is not really an issue in warm climate. But it can happen in cold humid freezing weather. Having your throttle ice up and stick open on a crowded freeway might be a little scary.
Opps sorry. I ment that the adapter did not have or connect to the exhaust crossover to heat it.
