Got a new pcv valve because they’re super cheap, replaced the line from the intake to the valve, replaced the line from the egr valve to the intake. Pulled the old egr valve and it didn’t look awful but the gasket was fused to it with some rust and it’s definitely seen better days, I could have just got a new gasket but I opted for a new valve. The old one moved fine, there was some gunk inside but not bad. Couldn’t put the new pcv valve in because I bought the wrong size grommet, I’ll fire it up whenever I get the right grommet and we’ll see what happens. I’m not chasing down a vacuum leak after this, if I suspect a leak I’ll just buy a gauge and check it. I should only have to pull the radiator to get good access to the timing chain (aside from pulling the water pump and dampener of course). I calculate roughly $150 for a new chain and gear set, new gasket and seals for the cover, and a new decent dampener. The job doesn’t scare me i just want to be sure that’s what it is before I commit. Is there anything that could be going wrong in the valve train that would make it run like this? Bent rods, stuck valves, lobe wear on the cam, Loose rockers? Just trying to think it all through.
