I did a 350->454 swap into my '87 K5 recently.
I searched for a bit and found a TBI 454 out of a running/driving 92 Suburban.
I got the entire engine including accessories, computer, and complete uncut engine/underdash wiring harnesses. I even got the air cleaner and the cruise control module. All for $800.
I used a 4L80E out of a 1994 Diesel C/K pickup. When I bought my motor, I tried to get the trans that came out of the same truck, but someone had beaten me to that part of the deal. I should have offered another $100 and tried to seal the deal that way. Unfortunately the trans I ended up with doesn't have the reluctor ring on the output so my computer is wired to the transfer case output speed sensor. This just means I can't put the truck in 4Lo without going in to limp mode. I have to tear my trans completely apart to put the $20 reluctor ring in.
I was incredibly lucky to find a 32 spline input gear at my local U-Pull-It for a NP241 I had on hand.
I put in an electric speedo cluster. I had a '81-'87 tach cluster in the truck prior to the swap and have since converted my electronic tach to house the tachometer. That is a bit of a job.
The engine fits in the engine bay without hassle. I have the stock crossmember and used the 350 engine mounts. I have good clearance.
I had to find fuel lines from the TBI to frame (454 is different than 350)
I already had a big block radiator in the truck. I used the big block fan shroud. I used upper and lower hoses for a '89 Suburban with a 454. The trans cooler hard lines hooked right up without problem.
The stock throttle cable worked fine. I mounted the '92 cruise control module on the inner fender. It was easy to wire it in to use the original cruise stalk in my truck.
I had a local A/C shop make hoses to connect the compressor to my truck.
I lengthened the Engine-transfer case strut, trans shifter rod, and transfer case shifter rod.
I had to move the trans crossmember back.
I had to get my driveline lengths changed.
I used Doug's tri Y headers. I used a heated O2 sensor in the exhaust pipe immediately behind the header collectors.
I am still using the vacuum brake booster. My intake manifold had a plug on the driver's side that I removed and put in a hose nipple for the brakes. I will convert to hydroboost if I have any trouble with the vacuum brake system.
I was going to use my built 700R4 behind the motor and use my '7747 ECM to run the 454, but after adding up all the parts I would have had to buy to make it work, it was cheaper to put in a $300 4L80E. To use the 700 I would have had to: Get a new flexplate (I don't drill flexplates), Get or make a TV cable bracket/arm (454TBI doesnt have provisions), Get adapters for my harness to mate to the 454 TBI, Get my '7747 tuned.... It adds up fast. The 4L80E is a much better trans.
The computer mounted directly into the '7747 bracket that was already in my truck.
I was lucky with my trans. It works perfectly so far. I will pull it apart soon for inspection and to put in the reluctor ring.
My swap turned out nice. It looks like it came this way from the factory. I hate swaps that look pieced together with a rats nest of wires under the hood.
The truck runs great. It has great power. It tows my boat or a dump trailer effortlessly. I get about 10mpg in town and almost 13mpg on the highway.
Before I put the motor in, replaced the pan gasket, timing gaskets, rear main seal, head/intake gaskets, and water pump. I also put in a mild roller cam (210/220 .485 lift).
If you have any questions, let me know.
Mike W
