$350 to rebuild a D44. Good price?
mtrdrms
Torrington, CT
My front axle seals are leaking and I dont feel like getting into that project. A local shop gave me a quote of 350-400 depending on parts that are bad. Good deal or shop around?
Just for seals i would say that is a little high. I can do that job in a little over an hour, and the parts can't be much more than $50 if even that
seems reasonable parts are cheap its the labor involved and at $75 an hour $350-400 doesn't seem outragous. If you want to do the labor you would only be in the project for under $100
They're not terrible to replace... I just did my front and rear end. Took about... 2 hours to fully unassemble, replace those, the bearings, and other crap, then reassemble them. I'd say it's worth saving the money to do yourself. Then you could spend it on other mods :D
Never Give Up
If you have a floor jack then do it yourself its not as bad as you think, any of the tools you don't have you are going to need eventually so take a break from this beast and hit it again tomorrow, remember what we do is for fun and to be original, I tackled rebuilding a T350 tranny before I touched regearing my axles because I read so much about how hard it was to get gears set up right, get a good understanding of what you are doing and it is not that bad
On one hand I think that's a reasonable price for a shop to do the job.............on the other hand I think you are getting bent over backwards because it's relatively easy to do at home..............pick your poison.
If that includes the inner seals for the inner shafts than that would be a good price...they are a bugger to get in/out.
