350 with vortec heads
brans87
- In Memoriam -
North Carolina
Looking to refreshing up old 350 engine for my wifes trucks and it has the casting #'s for prone head cracking problems.
Thinking of going through it on a real tight budget and maybe doing vortec heads. I know I would need to swap intake manifold.
So can I get some info from guy's here that have done this swap and what to expect. Not looking for anything crazy good reliable engine.
It’s a buyer beware concern. Those heads can be found cheap in useable condition
A lot of times they need machine work to be useable, driving the price above an aftermarket head. Vortec heads are also prone to cracking
note already thought about the fact that used head could need more work then new ones.
Any recomm on set of decent aftermarkets that won't kill a budget?
Honestly got to get to hammering on wife's truck because she deserves it and I had wasted alot of time screwing off. Old motor runs but noticed timing chain is rusty and might as well do it now so don't get truck done then have to rebuild engine.
She has already say no to LS so that is out. She likes old school look for her old truck.
You can get a set of new ones for $600, which is the route I went. The intake manifold will also be an additional expense-Edelbrock makes a good one. If you can check out a set of heads before you buy, then used would be a good bet. I can tell you a bit about my experience.
I also used the newer style Vortec reusable manifold gaskets-no worries about sealing and they're reusable. Vortec heads can't accept a whole lot of cam lift (I think around .475 is about it) without machining, so keep that in mind. I was using a Comp 4x4 cam, so it's biased more for low end torque and not an issue. I went ahead and got the Comp roller tip rockers in 1.52 ratio for a touch extra lift. If you do change rockers, make sure you get self-aligning ones. The install went smoothly-other than needing the new manifold it's a direct bolt-on. I found that for the headers I was running, the multi-piece GM stock exhaust gaskets worked the best (Vortecs have a slightly different exhaust port shape, but will accept SBC exhaust manifolds). As always, get a decent set of head gaskets (Fel-Pro blue works just fine for daily driver applications) and a new set of head bolts.
Performance-This will obviously vary depending on your setup, but I was pleased with the result. Truck feels significantly stronger off the line, and barely needs any pedal moving around town. On the highway, it requires less gas to maintain speed on level ground or up an incline. It's by no means a high-rpm screamer, but it was never set up to be. The Vortec heads produce most of their gains down low. I'd say if you can get them for the right price they're ideal for a daily driver. If you're planning on significant modifications you'd probably be better off with aftermarket heads. If you want something reliable with a bit of extra performance then the bang for the buck is hard to beat without going to an LS platform.
where can you get a set for $600?
I bought this set up years ago and also got a set of center bolt valve covers as well. I put headers on at the time and my camshaft was only a .460 lift and I had plenty of valve to piston clearance as well as .070 clearance at full lift on the springs. Also put in a waterpump bypass on front of the intake.
I also reworked the quadrajet by changing the secondary metering rods. all in all it was a great upgrade over my pretty much stock 883 heads.
http://sdparts.com/i-23896377-sdpc-sd8060kit-vortec-head-kit-edelbrock-performer-intake.html
The JEGS manifold is like $115. been working great for me. I have Craigslist S-10 V8 swap shorty headers with keyed header bolts. zero leaks. I just put on a set of JEGS chevy center bolt circle track valve covers. They were the least expensive and are an inch taller (for 1.6 rocker arm upgrade which is easy). I went back to cork valve cover gaskets with the new covers. The factory covers and rubber gasket just wouldn't stop leaking when the truck was on angles.
I went the vortec set up from SD also.
Prices have gone up since.
I also got a cam, pushrods and I sprung for the modified heads for higher lift.
Paid around 1200 for everything.
I picked up a set used centerbolt covers and bolts and repainted.
Vortecs are 64cc vs probably 76 cc you have now is going to raise the compression a bit.
So if you want screw in studs that changes your options
With a set of cast dart heads or alluminum heads you won’t need the intake so whatever is the best deal is the route I would go.
And there’s nothing wrong with the stock intake either.
When you dive in I would take measurements to see what you have and calculate CR. I’m just under 9 and is fine on the cheap pump gas.
