MrSchaeferPants
So I did notice a while back my air filter housing has tune up info with some strange numbers, like 2 degrees for timing, and a .60 spark plug gap.
AFAIK it's never had a .60 gap, as I know the two previous owners. I put the plugs in at .45 when I got it all back together since that's what they were before. It did run ok beforehand, minus my lifter issue, and tapa tapa tapa...
So after my cam/lifter installation, it's been running like crap, there's no power, rich, hard to start, hot or cold. Could be a myriad of things, float level (as I did rebiuld the carb, but it was fine before) dist I know needs some work.
But I'm going to try the specified .60 gap. As it says on the air filter housing, and my book does say 350HD CALIF .60 gap, all others being .45.
Dunno if this is a question, but I would like some input. Couldn't hurt to try.
Doing a compression test as well, spark plugs look good so far, beer run got in the way after starting and stopping on #1
I just want my rig running better.
) I realised that one morning when I opened the hood to tinker with it and noticed the plate was a bit open, and couldn't push it closed with my finger, then moved the throttle by hand and saw it close.
