Well guys, I have been trying to love my upgraded 350TBI engine but it just doesn't have the grunt required to move around this big heavy Suburban, and fuel economy since the gear and tire swap has dropped to 10mpg. I could live with the milage if the power was there, but on a hot day with the A/C blowing, I am still losing MPH going up long inclines and the merging performance is less than stellar.
I have purchased a nearly complete 1988 454 TBI engine to build to replace this small block and will be putting the small block into my 51 Willys wagon instead of the 4.3 V-6 ( why have two underpowered 4x4's?) Plans for the build are an Edelbrock top end on an otherwise stock, quality built, short block. I already have a modified 454 Throttle body and injectors and an Edelbrock TBI intake from a previous project. I plan to use the Edelbrock 454 TBI Aluminum heads and a TBI friendly cam,and Thorley headers into my existing 2 1/2 dual exhaust system.
I would appreciate any comments on this package from those with experience with these components or this conversion. I would also appreciate any experienced advice on cam selection for more power while still keeping the computer happy. I am building this more for low end grunt than top end pull, the heads are probably overkill but the wieght savings appeals to me as does the slight compression bump. Any wiring issues, fitment or mount pitfalls or any suggestions or help will be appreciated. I used the search engine and picked up a few tidbits but thought I would ask for the most up to date info.
