355 SBC engine w/aluminum heads, GONE.
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
SOLD LOCALLY - NO LONGER AVAILABLE, THANK YOU.
Hi guys, I finished swapping the 489 BB in my truck and now i have the 355 SBC sitting here I would like to sell.
This is a 350 block bored .030" over to make 355 CID. Compression is about 9:1. The cylinder heads are 1988-1991 Corvette aluminum cylinder heads with mild gasket match port work done. They have new valve seals and competition cams dual valve springs. The camshaft is a mild Comp Cams Extreme 4x4 hydraulic cam. .462"/.480" lift with 218/[email protected]" duration.
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=96&sb=2
The intake manifold is an Edelbrock Performer RPM. Comp cams pushrods, self aligning rockers, and stock centerbolt valve covers. These components all have about 2000 miles on them since the swap. This engine should make around 340 hp and 400 ft-bs of torque.
The block and rotating assembly I do not know how many miles are on them. It is bored .030" over and doesn't burn any oil, but since this engine came in my used truck I don't know the miles (I've replaced everything except the block and rotating assembly). It has all new gaskets and a new oil pump (2000 miles ago), and doesn't burn any oil.
Pistons, crank, rods are all stock or stock replacement.
This engine is complete from intake to oil pan, with accessories, brackets, and pulleys and belts. The water pump has 10k miles on it, the alternator has 8k miles on it(genuine AC Delco unit), the fuel pump has 1500 miles on it, the power steering pump has about 1200 miles on it. All in great condition.
This engine needs a carb, ignition, and starter to run. $775.
If you prefer I can remove the RPM intake and include an Edelbrock performer intake and also a running reman Quadra-jet carb, your choice, same price.
Which means you only need ignition and starter. The installed RPM intake will not fit that carb.
Since I don't have any iTrader feedback yet here is a link to my eBay feedback so you know I'm not a shyster.
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=folkenheath&ftab=AllFeedback
Hoping to sell it here on CK5 locally is possible.
I would like this thing out of my garage so e-mail me if you are interested.
[email protected]
Thank you.
Yes it would bolt up, worst case you might have to oblong the middle two intake bolts on each side for angle. These are ZZ4 crate engine heads, also came on 88-91 Corvettes.
You would also want to make sure you can tune the TBI to work with this camshaft. The cam specs are listed on the link in the ad. Or you could do a cam swap before you install the engine in case the TBI won't work with that cam, I can't answer that one for sure.
Price reduced again, hoping to get this out of my garage.
Heath
