35x12.50 or 35x14.50?
irocvette355
Registered Member
Falls Church, VA
Blazer has (in progress) 4 inch lift front
4 inch shackle flip in rear with 1" zero rate
3.90's front and rear 700R4 208
Daily driver, light off roading, moderate towing.
What do you guys think would be better for this setup?
how wide a rim are you using? if your still rolling the 10 bolt axles id go with the skinnier tire just for the heck of it
Run 8 inch wide and the 12.50's , will look better , and end up taller with flatter sidewalls . 10's will let a 12.50 be shorter and look rounded on the sidewalls .
14 wide is a nice gnarly looking tire , but with the appropriate rims and spacing , will load the bearings and ball joints a lot .
Back when I ran 35's, they were 35x14.5s on 8.75" wide rims. I had a 4" susp and a 2" body, it was a tick high for the tires, so prob a 4+1 would be right.
