I run my 33s at 28 psi cold and they wear nice and even across the tread. You could start there and move up/down as needed. Could try the chalk test as well, do some searching for that info.
agreed, In that range of tire for a full size ive found 30 psi to be my sweet spot. I ran up to hollister about an hour away at 35 psi and the ride was rough as hell. I aired down there so when i was airing back up i tried a tad lower at 30 psi for the trip back and it made a world of difference.
That's the info I'm looking for. I am about to swap my springs from ProComp to TC and added ORD's greaseable shackles swaybar disconnect. Can't wait o see what the ride will be like.
