Swampwalker3
Registered Member
Odd. I was going to use a set of shafts I had from the bum axle to use in this one but ran into an odd problem.
The long side is 36 3/8" which is actually a tad bit shorter than a SRW shaft. However, this shaft will not completely seat against the wheel hub..
The short side is 32 1/4" long which is actually longer than the SWR short side yet this shaft will fully seat against the wheel hub.
I was thinking about just cutting down the long side because I thought it to be too long but...
Im mainly just curious about this situation.
