37 inch tires and 4:10 gears? (offroad use)
gmcjimmy88 said:
Did not think about that. I felt that the gearing was perfect with the 33's. I went down Daniele at Uwharrie in low/low range with my brakes out. Was really concerned but made it through. They were not all the way gone but was not even left to stop me with it in gear. By the way it was the worst part of Dan that I went down. Not a fun thing I want to try again.
you forget about your e-brake man? Or was is hardcore stuff?
Well my ebrake doesnt work either. My brakes took a complete crap and still are not working right. I have replaced everything (except the right rear wheel cylinder which is good). I replaced the booster, the master cylinder, both of the porportioning blocks, all the lines are good, both new front calipers. I still dont have any pedal at all. I had to disco the vaccuum line and run manual brakes. The pedal was about an inch from the floor when I started to have brakes. Then it would go to the floor with in a second or two. I managed to make it without much problems. I added a few dents but they just add charactor right.
TruckNutzDude said:
I'm running 44's with 3.73's!!! The 5.13's are in the big box from ORD waiting to be installed. I'm really, REALLY glad to have the SM465. :thumb:
I have to install mine too.... :blush:
I brought my pinion for my 14bff today...
I'm going to press the bearings on today here at work. :D :D
