37"x12.5 r 16.5 goodyear wrangler mt tire
86 4door
pottstown PA
can you mount the 37"x12.5 R 16.5 LT goodyear wrangler military hummer take off tires on regular non bead lock non-runflat rims? the trucks not a rock crawler, the rims i got are aluminum american racing. the reason that i ask is almost every body buying these buy the recentered bead lock rims, thanks
Fo sho. I just bought four for $300. They're a good buy right now.
pic of mine on 37" take offs. got them 50 bucks each picked from pile of around 100 tires.
k30 with 6" lift and 37" take off tires on 16.5 x9.75 rims. fit perfectly.
good bang for cheep buck if you need tires. not the best off road in mud . hard rubber so cind of slick no real grip. and for a big goodyear tire thay ride o.k. might take a lot of weight.
fyi check the d.o.t date code for age. lots of the tires are 10+ years old .
read a dot # on a tire = next to the bead /rim edge its molded in. go to the last set ( 0903 ) would = 9th week of 2003 made or ( 457 ) would = 45th week of 1997 and last example ( 3400 ) 34th week of 2000 . hope this helps.
and if the tire has some slime inside clean all of it out. its the lube thay use to get the run flats in and out of the tire. it will cause you big vibration problem.
