37x13.5x17 with 4" lift and D60/14B
87Whitey
Dallas
Alright guys, I had posted earlier on my 10/12 build and everyone talked me into the D60/14 combo. I pick them up this weekend from a guy in one of the local clubs I know.
Now my original intent was to go 35's with the upgrade drivetrain, however in reading through many of the postings here, I think I would be better off with 37's to compensate for the ground clearance with the larger 14bolt. I am going to use some 4" HDs up front and plan to trim a good bit in the front, it looks like several people have done the same setup to keep the lower COG.
I plan to use the black rock crawler rims in a 17x8 (to ensure clearance on the 14 and 60 rotors) and a ProComp Xtreme A/T 37x13.5x17.
Should I go with a 16.5 config? seems like more tires are available in the 36 + range in 16.5 than 17. The only thing I see is the advantage is the 17" safety rim bead. Price for tires and wheels are fairly close so I want to make sure I make the right technical choice.
Thanks
Steve
It sounds like the setup (suspension and tire) that I will get to sometime in the near future. I haven't decided on wheel size (I have 16's now), but the 17's look to be what I prefer at the moment...
The 35's are a little too small with the 14 bolt. Shaving will help.
Thanks Mouse...how are things up in MT I am a WY native...moved to TX to make a few bucks but wanna get back up to MT/WY
FYI I forgot to add I am also considering a 16" wheel, there a a few guys around that have some 37"x12.5 16" around for good deals on 90%+ tread.
What would be the optimal backspacing using a 8" rim, I like'm tight :-)
4.25" or
3"
Thanks for the help
Go with the 4.25. I have 10 inch wide with 4.25 back spacing, and the front is too wide for most trailers, and is wide on the trails.
I bet you don't miss MT/WY today...high of around 10 degrees here, and we've had almost 20 inches of snow since Saturday...
I second shaving the 14 bolt. Very easy to do. There is a thread in the tech section that takes you through it in a step by step process.
Make sure you shave the 14. Unless you want to run H1 wheels use the 16 or 17s.
tires are being faded out for the 16.5's. slowly but it is happening. 17's are taking the place of 16.5 but tires are not as plentifull yet. honestly i think the 17's are being faded out already. 18's are moving in fast and im thinking thats going to be the way to go.
grant
hack500 said:
imo, safety beads are overrated.
You must think aproach angles are overrated as well. Is that a snow plow you're wheelin with or your bumper?:haha: Just giving you a hard time that's all:p:
16 or 17 are fine. If you run 14FF discs 17" wheels are a plus, IMO. If you want a sweet addition for the 14, buy a razorback diffcover from DIY4X, the bottom of the cover is already set up for a shaved 14bolt. I used it as a guide this weekend when doing my swap.
Where in Dallas are you??
Thanks for the help guys
I ended up going with the 16.5 since I got a really sweet deal on (4) Goodyear RT II's - brand new and (4) with about 90% tread.
Leper - I am in Carrollton
I have been looking at the rear disk brackets DIY has, I look at the diff cover they offer as well
Hey gang
I might be a little behind in the new technology on wheels but I thought that you could not go bigger than a 16.5" inch wheel when offroading because of the tire would come off the rim. Is there a rim bigger than 17" now that keeps that from happening?
In general half inch size rims do not have a safty bead.
