As you get closer to a more square (1:1) bore to stroke ratio the motor will produce more bottom end torque. A 383 typically has a stroke of 3.750 and bore of 4.030-4.060, whereas the HT383 from gmpp has a bore of 4.000 and a stroke of 3.800 which should help it produce just a little more low end grunt.
Generally, longer stroke motors tend towards bottom end torque and tend to be slower revving and harder on parts (not always the case, I'm sure your 383 will rev much quicker than a stock 350). Shorter stroke will rev quicker and easier (race car motors often have short strokes).
The rods typically used are 5.7" or 6.0" rods. The length of the rod determines how the piston moves. A longer rod will give you more low end power, but a shorter rod will give you more top end.
It all has to do with the rod ratio. For a 383, the 6.0" rod will make between 1-2% more power throughout the powerband and will last 1-2% longer. This is because the longer rod keeps the rings from digging into the cylinder walls as bad as shorter rods. The downside to 6.0" rods (other than cost) is that the piston has to be shorter which can cause piston slap issues.
5.7" rods work fine and are a perfect compromise IMO (stock 400 use even shorter rods than this)
When comparing the runner volume of heads, assuming the runners are of equal length, the lower volume runners will give you more bottom end while sacrificing top end (equal length but lower volume indicates a smaller cross-section). The vortec heads everyone is so fond of have an intake runner volume of 170cc, which is part of the reason why they produce some solid torque numbers.
Pretty much. Smaller intake runner volume = better low end torque while hurting top end.
IIRC when you are going for low-end torque, flow numbers for heads are not quite as important as port velocity. Hopefully someone can confirm or deny. I will update and/or edit this as I find out more.
Flow numbers are important at any RPM. Your engine won't make optimum power (or torque) unless you get as much fuel and air into the cylinder as possible. The cam, intake, intake runners on the heads, etc. determine where the peak torque will be made.
When looking at heads make sure to compare the flow numbers at all lift heights.
Anyone got some guiding principles for choosing cams, intakes, or carbs especially as it relates to maximizing low end torque? I am a total and complete novice without any experience... so learn me something.
In a truck you will want a dual plane manifold. The carb determines whether this will be a street truck or not. The cam also depends on what you are looking for.
