the_mule
Registered Member
Pace performance sells vortec heads cheap, and cut around the valve springs for more lift. Remember that you need an intake, valve covers, a different temp sensor, and the bracket for AC wont fit even if the intake has the holes for it
Is the rotating assembly internally or externally balanced ?
Just a side note the flywheel on a one piece rear main seal is different that a 2 piece rear main motor. So depending on how the engine is balanced 400's came internal in the front and external in the rear, you will have to use a flywheel that is balanced for the rotating assembly, or not dependign on the setup.
I personally bought a internal balanced rotating assembly for my vortec headed 383, so I could put any flywheel on it (also running a sm465).
. later
