jagermiester
I have a 10.5:1 383. it had a 168 tooth flywheel and a small block chevy starter. It works for a while the grinds. This is how I got it. So I replaced the starter and re shimmed it (one shim) and it was good and the a day later started doing the same thing. So last night I replaced the flywheel and I want to get the right starter so I dont have too do that again any time soon. I started asking around and this is what I was told.
1. There are 2 different frlywheels for a 400 153 tooth and 168 tooth
2. A standard small block starter (ie 1983 350) will only work w/ the 153 tooth
3. The starter that will work for the 168 tooth is one of those mini torque starters
4. A 69 camaro with a 307 has the starter that would be needed to use the 168 tooth flexplate
Can anyone tell me if any of this is true. I do know that a standard starter does not seem to work w/ my 167 tooth flywheel. I tried no shim, 1 shim, 2 shims, 3 shims, and 4 shims no of which worked please help
I figured that a starter made to turn over a 12:1 454 could turn over my 9.46:1 388.
..NOT!
