A 383 stroker is a 350 block with a 400 crank to be blunt...
The 350 has a 3.48" stoke and a 4.00" bore,
the 400 has a 3.75" stroke and 4.125" bore,
350 rods are 5.7" long center to center,
400 rods are 5.565' long center to center,
First you need to know that the rod ratio is calculated by dividing the length of the connecting by the length of the stroke...example: 5.7" / 3.48 = 1.62:1
common 383's use a 3.75" stroker crank, 350 block and 5.7" (350) rods.
This particular combination has a very poor rod ratio (1.52:1) and does not like to rev over 5500rpm, the ideal rod ratio is (1.75:1) but cant be be done to a 383 unless you acquire a tall deck block because the rods would have to be over 6.5" long and that would place the piston pin at the top of the piston (talk about dwell time.....wow)
I am presently having a 383 built using 6.0" rods on a raised ring piston which places the pin into about the center of the oil control ring,
this combination will give me a (1.6:1) rod ratio which almost identical to a 350cid engine which has a (1.62:1) rod ratio.
Short rod motors make torque down low......
Long rod motors rev till the sun goes down....
and the middle of the road does a little of both.....
standard 400 cranks have to use sleeved main bearings since the main journal is a smaller diameter on the 400 crank than the 350 crank.......
so now custom stroker cranks are readily available with a 3.75" stroke that drop right into the 350 main journals and use standard bearing shells.
hope this helps ya....
