Go for the 383.
If you have the money, put some good performance parts in it while you are at it. I kind of went all out on mine, but it was worth it. The 383 in my c20 pickup puts the stock 350 in my blazer to shame, and the pickup is loaded with tool boxes, tools, ladder rack, and ladders. I have not driven in a truck with a stock style 383 to compare them.
I used edelbrock aluminum performer heads, with 70cc chambers, since mine were toast. A good set of worked over steel heads are not cheap. My cam is small 204, 214 duration at .050 and 420,442 lift. It has great low end torque but pulls nice to 5000 rpm. I ran roller tipped rockers (couldn't run tall valve covers, so I didn't mess with full rollers), aluminum intake, flat top hypereutectic pistons, estimated 9.6:1 compression, msd ignition, 600cfm carb, tri y headers and 3" exhaust. I had the engine balanced but not blue printed. This combo passes Cali. Smog with no problems. I run my timing at 10 degrees advanced initial and have my mechanical advance set to come in as soon as possible (2500 rpm on the msd chart), with as much advance as the distributor will allow. I do run 91 octane, but I get the same fuel mileage as the old 350 that I pulled out, and I have a heavy foot. 8 mpg normally with Gearvendors overdrive, and 5 mpg towing my 21' toy hauler that probably weighs around 8,000 lbs. I can pull my trailer up a 6% grade at 60mph at full throttle on a warm day. I’m guessing my gross weight is about 15,000 lbs.
About a year ago I was quoted $4,300, from a reputable shop, to build a similar long block 383 for my blazer. In 2003 I paid $2,300 for the short block parts and labor, and the labor to have the heads, intake, water pump, and fuel pump installed (I supplied the top end parts to the builder) for the 383 in my truck. They gave me a 2 year warranty on the engine. I now have 72,000 miles on the engine without any problems.
Hope this gives you some ideas. Good luck.
