4x4k20
i have a 79 with a 383 its a 350 bored 30over with 400 crank and rods with vortec heads 10 to 1 compression i had the timing set at 12 initail it ran good and had good power but if you cut it off it would not wont to start back so i set the timing back to 8 it will start but has no power what do you guys that 383 s run you timing at ? i have always had to fool with it it will run good and have good power then i would get some pininging so i would set it back wouldnt ping but wouldnt have any power i have to run 93 octane in it any ideals would be helpful
