Just to be clear, what is this in? My low budget suggestion for a cam is the lt1 stock cam. If you are using the stock long block the current pushrods will be fine. I would be careful on 1.6s, for 2 reasons. First they like to float valves and second you are getting close to seal to retainer bind on stock vortec heads (.457 on the exhaust if I found the right specs).
