39.5 Boggers on MRW Beadlocks
mtnman210
Northridge, Ca
I have a set of 4 39.5x18x15 tsl Boggers. They are mounted on MRW extreme duty 36bolt beadlocks.They are 15x10 with Chevy 8 lug bolt pattern. The beadlocks are all grade 8 botls with no stripped bolts. All The tires hold air with no patches or plugs. I've never had an issue with leaking beadlocks. Tires have normal rock rash but still have 80-90% tread.
$1100 for the tires
$650 for the beadlocks
Tires and wheels are located in Thousand Oaks, Ca and prefer local pickup only
they're not light. I can weigh them if you really want but yeah I'm sure shipping them wouldn't be cheap
You still have the bead locks and if so will they work on 14 bolt ff and Dana 44 front setup? I was under the impression you had to go to 16 in wheels to clear brake set ups is why I ask.
