395/85/r20 will they fit
the_goat_man
flordia
ok i know thes tires are hard on drive train and other stuff but found a good deal on them i was just woundering if they would fit under my truck?
it has a super lift 12" kit on it. it is a project for me. i under stand that i sure i have to cut the fenders but is it even worth it? and if you have pic that would be sweet.
They measure 46" so you will need to move your axle forward about 4", cut the fenders and put on some bumpstops.
Do they look like these:
Unless you're running Rockwells don't bother. THEY ARE HEAVY AS HELL! Load Range F or so tires meant to hold up a 40,000lb or more truck...your 1 ton axles aren't up to it.
attachment.php
attachment.php
They're also not super aggressive so unless you have tons of power to go with the needed Rockwells they don't self clean like a Bogger.
