3d printed gauge panel
eodcoduto
We could have been closer.
Muscle Shoals, AL
The turbo cartridge is finally arriving Monday for my Banks kit, it took 15 weeks to get one! So I am starting the install and doing all the boring stuff now so I can have my down time to a minimum. I wanted to mount my gauges but not with a tacky 2 gauge tin panel, and I don't like pillar pods so I made this.
My gauge bezel is for a 89-91 and I don't run a radio so that was a great spot. I made the gauges angle up at 10 degrees and I am happy with the results.
It was printed on a Taz6, ABS filament and took 2.5 hours and cost $1.47 to make. 3d printers are great for small brackets and obsolete parts that I don't want to make out of metal or wood.
That’s awesome!
Would you be interested in making these for others? I don’t have a/c and would love a single gauge insert to go in the bottom left where the headlight switch is and a blank for the top right to add switches to.
Dude, you freaked me out for a second. I thought you were printing the whole gauge cluster cover. That would surely open up a lot of options.
As for your 2-gauge insert, why not add some holes to line up with factory sheet metal holes (for screws) and/or some hook/tab features to grab the inside of the steel radio opening?
Can you read the gauges well down there while (imagining you are) driving? I know I have trouble seeing the radio.
That’s awesome!
If you can get me the measurements I will draw them up and print them, I have enough filament right now to do a few prototypes.
I thought about that and I might make a V2 that snaps into the bezel, my radio sheetmetal is hacked out by what looks like a sawzall and meth combination so I couldn't use that. I can see them from my test fit, I will know better once I get it all buttoned up and road tested. I have some glow in the dark filament too, and the green is bright!
