3R or 1330 yoke for 12b
TerryD
Mildly demented...
Covington, Va
Needing one, preferably with u-bolts instead of straps, but what ever you've got. Price shipped to 24326!
If you need a 1330 it will be for a 10 bolt.
You can put it on a 12b but you will need to change the seal on the 12 bolt because it's a different size.
And you won't find a 1330 in U bolt, it will be strap.
1310 would be a 12b Ubolt style.
I should have both, which do you want?
I have a GM style 3R yoke from a 10b. The blazer uses the 3R joints and had two 10b's under it. I'm swapping an older 12b that has 1310 yoke on it and need a 1330 or 3R yoke for the 12b.
I was hoping someone had the aftermarket yoke for the 12b that accepts 1330 and uses u-bolts. Both yokes I have, 3R and 1310, use straps. Did that clarify any? :confused:
Then you need to pull the 3R yoke from your 10 bolt and put it on your 12b and get the right seal, or get the conversion U joint from napa to mate your 12b to the 3R shaft you have.
I did just that last night. You use the factory 10b seal in the 12b housing. Worked fine! Thanks man!
