4.56 gears for 14b
muddybuddy
1 ton status
Northern, VA
well since i can seem to find a complete 14b with 4.56s, guess ill just regear my current 14b. its got 4.10 and down carrier, so i need 4.56 gears (ring and pinion) for that carrier. the cheaper the better :D already on a carrier, even better;) but let me know what you got. thanks
Damnn, I have two sets for the other carrier, and one of the carriers you have to... No help to you I know.
well do you have the carrier to go with the other gears? if so, i might be interested :)
I have a set that comes with the carrier, the pinion support, and gear set so all that has to be set is the backlass and all the bearings are good. Like $175 for all the parts.
bigred81
Muddy, I set the gears up in my axle not too long ago and it was a lot easier than I thought. Only thing that is a problem is setting the pinion depth. Backlash isn't hard at all. Just go to harbor freight and get a magnetic base and a dial indicator.
