4.56's w/ no locker
stumpbuster
farmington, Ct
i picked up a set of 1tons w/ 4.56's, but the 14bolt does not have a locker.
i was under the impression that 4.56's were an option from a military rig, and the only way they came was with a locker.
kinda confused.
anybody happen to know what my donor vehicle coould have been, or have a gear ratio chart?
they made 4.56 gears for other vehicles besides military...
I have an open carrier at home that is 4.56 that came from a C&C truck...
ok so i dont have a raped set of axles
not sure why i was under the impression that ratio only came w/ lockers
Cab and chassis civilian 14 bolt with 4.56 and open diffs are common. I have had one.
my truck is a 1978 chevy cheyenne camper special.... 8400gvrw... 4.56's factory and no locker... well when i bought it.. it does now... :woot:
If i recall correctly the m1008 (1 1/4 pickup) which is probably the military truck your thinking about came with a detroit in the rear and an open front which might have been what you were thinkin of.
yea, and 4.56's
thawt it was the only animal
Hey bro! Yesterday i bought rear and front axles , and that pic is the rear they are 4.5 btw what kind of lockers is that?
dabbas we told you its a detroit by the spring showing in the windo of the carrier the ring gear is bolted to.
cant belive you found those that easy over there tho. you must be lucky or know people. :whistle:
