4.8 with th400...is it enough? Solved...hopefully...
TxM1009
Texas
I've got a 4.8 V8 out of a 2003 tahoe...I was thinking of swapping it into my K5 and running it with my th400...I've heard mixed reviews on this combo...ranging from it's a great combo to it wont have enough power to move under it's own power....I'm not looking to build a racecar or a rock crawler or anything...just something to cruise and do minor off roading in?
Should I send it or go back to the drawing board?
Well, we’re missing a lot of info, like gears, tires, other mods that add weight
“Enough” is subjective
Unless it’s tuned on kill, probably not enough “for me”
I assume that 4.3 in the description is a typo and you have the 4.8 in the title. The 4.3 v8 does exist and sucks. My contractor van has the 4.8, its ok but thats all. If I were doing a swap I would want more power. Loaded up with tools the van is pretty slow, a K5 with some gear and larger tires is probably going to leave you wishing you had done a 5.3 or 6.0.
Well considering the 4.8 has about 100 more HP than anything that came stock in a K5, I think it'll be just fine. Your truck still won't be a rocket ship though
This is what I've been told
"Yah, 5.3 isn't really a towing motor either, but at least it would have enough to be able to drive the truck relatively normally. Not with the 400 and factory taller gears tho. You would still need short gears. Pretty much nothing ls-based is going to like the 400 and tall gears. A 400 is usually set up from the factory to upshift around 35-3800rpm, and at 4000, even with the shifter pulled down to 1st, it will automatically force an upshift (and a violent one, at that) to second gear. Now in most cases, LS engines are just getting into their power band at that rpm (including the 6.0), so the 400 is a total waste of LS power. You are doing an LS swap just to be able to fit in with the 'in' crowd and say that your truck has an LS swap. But you aren't thinking about what all needs to be changed to make it work in that truck. You are trying to get away with cheaping out and doing a bare minimum, when that isn't going to work for that truck the way it's currently set up. The little LS engines are not designed to be heavy truck motors, and you will have nothing but problems if you carry on with the way you have planned this swap. So either bite the bullet and build the truck properly, or give up on the LS and just build up a good RV 350 for it instead. It would work way (!!!) Better than those little underpowered screamer LS engines"
The LS sure do rev high. As a lifelong chevy v8 guy the LS freaks me out with the crazy revs. I know they are supposed to work that way. I drive one of 3 squares most of the time, old school, low reving v8's. When I take out my '05 Silverado and set the cruise control it makes me think its going to blow itself up. Downshifts and takes itself up to 5000 rpm and sounds like its going to explode. Even with the 6.0 it will still rev way up when pulling hills, just the way they are set up. 4l80e in that one. I guess I hadn't thought about the shift points in the turbo 400, all my squares are stick shifts.
More relevant info is that it came from the factory with the 6.2 diesel and the beefy axles and suspension that came with the M1009s
the M1009s really don't have any beefier axles or suspension than any other 80's era K5. now if you are talking the M1008 or variant, they came with 60/14 with 4.56's and Detroit Locker in the rear, they were all set up on one ton frames from the factory.
Front is a 10 bolt and rear is a 14 bolt. Is that the usual k5 set up?
I traded my 4.8 off.
Towing was bad enough, but the automatic door locks, press brake to shift, inability to just run parking lights all just pissed me off one day.
Felt like the truck was driving me...
FWIW I run a 5.3 Gen 5 with a TH400 NP205 and 4:10 gears with 37" heavy ass race tires. It gets 14mpg on the highway trips and cruises at 75 no problem with full gear and spares. The only thing that is lacking is crawling, which I don't do a lot of, and will be fixed with a magnum. I want to put the 8l90 in it when money falls out of the sky. The 5.3 is at the borderline of not having enough power in the deep sand or towing heavier vehicles off the race course. The trans swap will help but it's fine the way it is.
I couldn't imagine running with anything smaller at this point. Next swap will be the 6.2 Gen 5
Been sober too long for that mess these daze...
