4 core radiator mount for 83k5
down4thakrown
flagstaff,az
what it says
top part
if u got one shoot me a pm /forums/images/graemlins/thumb.gif
I have one from a 78 not sure if it will work or not I can send ya a pic? /forums/images/graemlins/dunno.gif
They are like $15.00 at the dealer. /forums/images/graemlins/thumb.gif
I saved this from a post a few months back.
"I did my 91 K5 awhile back. I got a 4 core radiator from AutoZone, part# 433730. From the dealer I got four new rubber mounting pads, part# 6264100, the upper panel (bracket), part #14018600, and the shroud, part# 14021289. Everything bolted right up."
[ QUOTE ]
[/ QUOTE ]
/forums/images/graemlins/waytogo.gif just copied those numbers into my parts book! /forums/images/graemlins/peace.gif
I found another one that Russ posted:
"Here are the numbers I used to purchase the parts from the chevy dealer:
#14018600, Panel Assembly, 1 each @ $14.27
#6264100, Pad, 4 each @ $4.10
The panel is the one that covers the top of the radiator for a 4 core. The four rubber pads are two for the top and two for the bottom to hold the radiator in place. I have used those parts to install a 4 core in my 90 Blazer and also in my 88 Dually, and they are a perfect fit."
i have a pair of 81 up 4 core mounting brackets
73-80 used a large flat panel full width(for =taller radiator anyways, but shorter oens for some of the 350's and the 6's used right angle panel mounted to front face of rad support down lower than usual, i just saw one at scrap metal yard today along with hood hinges and trans linkage setup and exhaust pipes and such all for 73-80 sbc trucks
67-72 used pair of van style brackets
you guys dont really know gm trucks too well ?
or ?
good luck
[ QUOTE ]
[/ QUOTE ]
I just pulled one of those off an 86 pickup that was bone stock /forums/images/graemlins/deal.gif
Last time we where up there you said you didn't have those brackets /forums/images/graemlins/dunno.gif /forums/images/graemlins/tongue.gif
Randy,
My GM 1990 RV Parts and Ilustration Catalog shows part #'s
14018600, Panel, upper radiator mount for 1985-88 7.4L
14039948, Panel, upper radiator mount for 1985-89 7.4L, 6.2
14022775, Panel, upper radiator mount for 1985-89 292
GM obviously used those panels all the way through 89 at least. I have put one on both my 88 model and 90 model with the Autozone 4 core radiator and they bolt right on.
Russ
