4 core radiator with shroud in OR
Bagh... I got some money now. I wonder if i should just pic this up for the burb. Any idea what year it was out of or perhaps some dimensions?
Pretty sure it was out of a 73-80 crew cab. I can get measurements tonight tho
If you can that would be cool. I think if it will fit in the burb I will go ahead and take it.
OK, it tapes out at 33" wide 21" tall and 3 1/2" wide...
I think the radiators are the same through all the years and the 81 and up models just use a different bracket for the top. But its been a while sense I've swapped that stuff around so I could be foggy on that.
The "ribs" that stick up either side of the core measure 28 3/4" center to center...
I'm heading over to Bend in about 2 min. I'll check back in a few hours
OK, so a few hours turned into Sunday...
Do you think the rad is going to work for ya?
I got a set of zero rates...if you still have the radiator
After some research it looks like it will work for me. You still going to be out of town this weekend?
Should be a go. If I have a day when I'm working out on your end of town I'll throw the stuff in my truck and bring em out
