Thanks guys,
I'm going to head to the junk yard and see what I can find. And yes I know the 160 is a cooler thermostat. I'm able to run more timing advance without detonation with the cooler thermostat. When we were tuning the motor we played with 160,180, and 195 and the 160 gave the best results. I dont' know what the stock 2 core radiators are rated at HP wise but I am sure I have exceeded it.
This only becomes an issue when its 90+ outside I have my boat attached and I am going up a steep hill. And even then it never goes over 200. And once I crest the hill the temp drops right back down. So I'm sure a 4 core would be enough to keep things steady.
What kind of cars should I look for that have a 4 core and auto transmission? I know I will need new brackets on the top to hold the radiator any ideas on where to get those?
Thermostat was just a suggestion, sounds like you've covered it.
Big block trucks and I think the diesels had the big 4 cores.
The one I took out was a 4 core!
