4 inch shackle with 4 inch lift
Loose Nut
Banned
Maryland
So this is the plan, i wanna go 4 inch shackle flip and a 4 inch spring lift, all that seems to be able to be obtained from ord.
My question is, has anyone done this? im sure there has, and if so what length shocks should i hunt for and other then a new steering set up, am i going to need anything else?
if ORD can give me a idea what i need, id like to purchase everything from them. I have a 91 gmc jimmy btw.
Thanks for the help everyone.
i got tc front springs, shocks, steering, ublots, flip etc all from ord
koldsimer runs that exact setup. Call ORD they will tell you what you need as far as shocks. You might as well go ahead and get the 6" shackle while you are at it. Get the 56" springs for the rear, they will give you more flex. The only thing you do different is mount the right hanger on the left side and vise versa.
thanks for the help. Thanks ORD for replying to my email as well :) we will get the show on the road shortly!
