4" lift 10bolt axle shims
suntadz
bay area, ca
I have a 4" rear spring lift and a c/v dirveline coming from np208 to my 10bold. From my ghetto protractor and level setup i used it looks like my drive line angle is at 25 degrees. My axle pinion is pointed up 5 degrees. anyone know whats axle shims I might need? I was thinking 10 degress but that seemed a bit much for just a 4" lift. Also I noticed it seems after the lift one side is about 1/2" higher then the other? Is this common? what would cause this? what could fix this? thanks for the info......
